QUOTE(second wind @ Oct 18 2020, 02:48 PM)
I have tried covering my clutch cable wheel and cable several different ways but nothing great....just changed my cable and it seems a shame to leave it out in the open like it is.....any good ideas to keep the road grit out? I think Mikey should be working on this but who am to say? Welcome ideas and it just makes sense to protect this vital area from contamination.....thank you for your thoughts,,,,
gg
I bought a CSOB cable and it was rubbish,I had already bought the 914rubber delron roller and its a great part,but after fitting the original cable with proper nylon liner had a huge improvement in pedal feel so don't buy the cheap cable
IMO make sure you have the rubber boot on the cable and don't use any lube ,stock mounting is fine for road grime even without the plastic cover which I have back on now,however if you have the horizontal TR setup you may pick a bit more grime up but is no cover to fit that.
