flash914
Oct 17 2020, 08:16 PM
Going to build a 1911cc. for my 1970 and already own a set of lifters. I read somewhere that the case needed to be opened 0.002 for clearance. Did I read this or will the lifters fit in the case just fine . Thanks in advance. Gordon
914werke
Oct 17 2020, 08:33 PM
Where did you get them?
When they were available my recollection was they are drop in.
But .. if you are building a motor, why not just measure ?
Jake Raby
Oct 17 2020, 09:19 PM
I ended up with all the oversize ceramics. If yours are the standard .943 they'll drop right in..
Mark Henry
Oct 18 2020, 06:58 AM
IIRC the first runs of lifters were .002" oversize, later were stock size.
If you got the very first small hole lifters it's best if you disable the lifter pressure relief by-pass spring with a short piece of rod.
I have them in my 2.6 and a I have a set on the shelf.
