QUOTE(Superhawk996 @ Oct 20 2020, 06:27 AM)
I gotta go against the grain.
It doesn't look like a front seal leak to me. Oil is too evenly distributed and too far back on engine and case. Air from fan primarily blows from top down. Sure there is some leakage around the fan shroud but really not enough to blow oil that far rearward. Plus it is a very thin dirty film. Unless you cleaned the oil pump off, I'd expect to see a lot more oil directly below the front main seal if that seal were leaking.
Appears to be coming from above. Most of the oil residue appears to be older.
Can be a variety of sources:
Bad oil temp sender that is leaking - this usually runs down on oil cooler. Since you said those were dry I suspect this isn't it.
Could have been leaky cooler seals that someone replaced but didn't clean up the mess.
Can be weeping between base of cylinders and the case.
Can be bad PCV valve causing pressure inside case. Though this usually shows up as leaksage under the oil filler tower / breather assy at the gasket between the case and the breather.
Can be the gasket to the oil filter tower. If you have engine out and easy access I'd at least put a wrench on the nuts and/or replace that gasket while you have easy access.
Do agree that cleaning the case and monitoring it and/or using UV dye is best way to ID the source.
Superhawk996, thanks for the input.
I'll double check the sender.
I replaced cooler seals (previously) in '98 maybe 7k ago and cleaned entire engine then.
Cylinders look a little dirty and need to be cleaned - not sure what would cause any weeping between cylinders and block. Might just be oil blown by impeller.
It's a 76 so no PVC valve (breather vented to air box) but I note air filter seems a bit oilier than I would expect. The breather always seems to have a film of oil on the front side so it could be the base of the breather box.
Will definitely check/replace the oil filter tower gasket - good idea.
Yep, gonna clean it all up again.
Thanks,
Alan B
