QUOTE(Superhawk996 @ Oct 20 2020, 07:21 PM)
QUOTE(Mark Henry @ Oct 20 2020, 07:02 PM)
I have a oxy/propane cutting torch, not as hot as oxy/acetylene, but perfect for cars. For me worth the bother of an oxygen tank and propane is way cheaper than acetylene.
@Mark Henry Acetylene has gotten expensive since that plant explosion back in 2018 that has constricted supply
Do you still use the same regulator(s) and tips or did you need new regulators to run propane? Do tell. I don't use much acetylene but my tank is getting low.
Even Argon has gone way up in last couple years with inflation + new Hazmat fees my gas supplier puts on bottles.
I just went to a welding supply shop and told them I wanted to convert, dude had me the kit in a second. IIRC the tip, sort of an inner tip and a jet.
This is 25+ years ago, 10 or so years ago I had to replace just the tip... I think?... But the welder supply had the stuff in stock.
BTW I go through lots of oxygen, but I get several years out of a tank of propane.
