QUOTE(Slipry @ Oct 21 2020, 01:16 PM)
Click to view attachment Just a little update! took tank out. had alot brown sht mud in sump. all clean now Had injectors out and bench cleaned WOW! what a difference, runs great Accelerates smooth,no more Poppin/Fartin Only thing still idles at 1400 Warm no obvious vaccum leaks Where should i look first??? Thanks again guys ������������
Well done getting it going,but in real terms a high idle is the sign of an air leak...keep looking pretty sure you will find some,have you tried to adjust the air fuel screw in the throttle body ?.
Good luck.
