I have all the RH goodies for an LS swap. Engine bar, electric WP, adapter plate, clutch/flywheel and full radiator setup . Also all the engine conversion bits, alt bracket, cooling plates etc. Probably 2000 miles tops on all the stuff, I just dont drive as much as I would like to. I also have the super slim oil pan that gives max clearance when running this set up, and the trans mounts too. Worked flawlessly, the RH stuff is proven.
RH-$4500
Speed Metal-$2600
No,
I dont want to sell any of it piecemeal.
Thanks,
