Hello. I am planning on enlarging my engine and would appreciate your opinion regarding my plans.
I have a 1.7 liter that has a big bore kit enlarging it to 1.9 liter. It is in need of rebuilding. My car will be used as a daily driver. I want all the power to be concentrated at the low RPM range. I want it to be easy to use for casual driving.
Rods: I will use 71mm rods from the 2.0-liter engine.
Crankshaft: I understand the crankshaft must also be machined to accommodate the 71mm rods. Am I correct on this?
Piston/cylinders: I plan to use a 104mm kit from AA Performance that would increase the displacement to 2.4 liter. I understand I will need to machine work the case and heads to accommodate the larger cylinders. These are not forged pistons which have piston slap. Forged is great for racing where the engine is driven hard and frequently rebuilt. This engine will see light duty. Comments?
Camshaft: I plan to use a Web cam from AA Performance. It is WC-00-152. This is described on the website as “Good overall performance for carbureted mechanical street engines. The perfect street cam! RPM range 2500-5500. .423/.423 Lift, 270°/270° Duration, 234°/234° Duration .@ .050 Grind #86”. I very much would appreciate comments on this? What is meant by “mechanical” street engines? Is this referring to solid lifters? There are camshafts listed on Pelican Parts but there is no verbal description for them. For all I know, I could be ordering a stock cam with no overlap.
Lifters: I plan to use stock solid lifters.
Camshaft gear: Is a new camshaft gear needed? Why are they aluminum? Are they intended to wear instead of the crankshaft gear?
Distributor: I do not know what distributor I will be using, but I want one with vacuum advance and a solid-state circuit. I know of a Pertronics distributor advertised for the Type 4 engine. Comments?
Clutch: I have a stock clutch and plan to continue using it. A heavy clutch makes a daily driver uncomfortable.
Starter: My current starter is a high RPM gear reduction starter. I plan to continue using it.
Carburetors: I currently have 44IDF carburetors and plan to continue to use them. Should I consider changing to 48IDF carburetors sometime after the rebuild?
I know these are a lot of questions but any comments would be appreciated.
Thank you.
