I have a set of 914 trailing arms that I need to figure out. They were used in a high HP application in the past I’m assuming ‘cause they have the welded-on box bracing added to each arm AND had cut-off stainless flexible brake lines. They also have Weltmeister poly bushings AND ZERK fittings for grease added! There was a 5-lug set up installed too - done with non-914 parts. Also, there is only 1 e-brake setup (driver’s side) and a single 911 splash shield (10 vent holes) behind it. For that e-brake to fit, I notice that a little of the left arm was milled away (where the 4 holes are that the wheel bearing sits inside of). These are NOT drilled 914 hubs, or 914 cv’s or axles..but I don’t know what they are exactly. The CV’s measure 108mm and the over all length of the half-shaft assemblies are approx 1” shorter than standard 914. The diameter of the shafts seem to be about 1mm thicker than standard 914 but paint is missing too, so..
I know they’re are several set up using 911/930 items and then 914/6 Specific parts Too. I want to know the specifics of what this is.. btw, the pn# on the 5-lug hubs seem to be 901.331.605.06. Or it could be 951.331.605.08 hard to see! There were no rear calipers or trans output flanges.
