is there any way to take a leaking pushrod tube seal and do something (short of replacing it) to make it no longer leak?
Mueller
Jul 14 2005, 06:55 PM
drain the oil
install a vac. pump to create negative crankcase pressure
Jul 14 2005, 06:58 PM
QUOTE (bd1308 @ Jul 14 2005, 05:52 PM)
take it out, clean it, put it back in ...
Andy
bd1308
link me to a vac pump......
scotty b
Jul 14 2005, 07:01 PM
Sounds like to me your car has a SERIOUS case of A.D.D. Push rod tubes, then oil cooler, then pressure switch, then push rod tubes all in 2-3 days
Trekkor
Jul 14 2005, 07:05 PM
Just turn this into a bigger maintenance project.
Replace the leaking seal. ( Or, go big and replace all the seals ). Change the oil, filter and adjust all the valves. Spend two or three hours and get some things done.
KT
