QUOTE(Tdskip @ Oct 29 2020, 02:22 PM)
Thanks
@BBrock - the brakes work, just a bit sticky. Will run it (safely) around a big empty parking lot for a bit to see if they free up some. I'd love to just rebuild these rather than have to replace, the 2002tii calipers turned out pretty well.
@Superhawk996 - go go go!
Tom something that has worked for me in the past is to remove the caliper/s take out pads and use a large clamp to retract the pistons fully outwards, reassemble and test.
Another method is put a wood spacer which will stop the pistons over extending and pump them inwards,you can then retract them again as per the above method.
The pistons stick due to a rusty coloured varnish that builds up on them and causes them to bind in the bores,the square section rubber seal cannot do its job of retracting the piston fully when there is no fluid pressure.
If they don't free up its time for a rebuild but this method has worked well for me ,just to add I always vac all the old fluid out and replace with new,I think that helps also.
Good luck.
