QUOTE(brant @ Oct 30 2020, 01:16 PM)
I'm not familiar with the specifications for a type 3
the 1.7 MPS from a 914 needs to have an extension ring installed in it to create the depth and flow characteristics of a 2.0MPS
at a minimum, I would think you would need the spacer ring from a 2.0 to make it work
I might have one in my spares if you proceed.
others on here that have more experience tuning with the meter will likely know more than me.
I've only tuned for 2.0's and only with AFR
brant
I have new 2 liter spacer rings.
Best way to set this up is rebuild the MPS with one of my kits and add the tuning option. Then install WBO2 in the exhaust for air/fuel measurement and adjust to best mixture in operation.
It will be necessary to trim the inside of the 1.7L MPS cover where there's a ring which extends further than the full load stop setting of a 2L MPS.
