since the driving lights go through their own relay the standard 16 amp fuse is perfect. The harness is there on every 914, white with yellow for the positive hot lead, brown for the ground. Factory driving / fog/rear window defrost switches are hard to find, but hella makes an aftermarket in the exact same configuration. Relay just plugs into the empty slot on the fuse block above your left knee
QUOTE(L-Jet914 @ Oct 30 2020, 09:16 PM)
I recently purchased a set of Euro Hella 118 914 driving lights to install on my 74 which are en route. The wires are all stripped with no connectors. Are the factory connectors male or female spade connectors on the light assembly side. Also I believe I will need to add a relay and switch to turn on the lights. What amperage fuse is used for the Euro halogen driving lights?
