QUOTE(phillstek @ Oct 31 2020, 02:24 PM)
QUOTE(FastFred @ Oct 31 2020, 10:26 PM)
HI everybody i'm new here I'm trying to find out what spring rate to use with front coil overs I'm building a street car so I don't want too harsh of a ride.
Thanks for the help
Despite what others say, it’s your car so if you want coil overs then I say, why not? I have them on my car and don’t regret putting them on. My car is significantly lowered and prior to installing them bump steer was so bad that the steering wheel was almost getting torn from my hands mid corner if the road surface deviated at all. Coil overs and raised spindles solved it and the car handles beautifully now.
I have Level 3 struts and solid camber plates and have not reinforced the top mounts and after 20,000 miles of driving on Australian roads there’s no sign of any stress in that area at all. Roads here could accurately be described as goat tracks and the car gets hammered.
I built the car to do tarmac rallies and track work as well as street driving so chose Level 3 but Level 2 would probably have been a better choice as most of the time I drive on the street. The solid mounts are noisy when hitting lane markers too but you get used to it.
Level 3? That means nothing to anyone here. Are there number assigned to different Levels?
Your bump steer problem had nothing to do with having torsion bars.
That being said, the most common rear springs used are in the 100lb to 140lb range so I would think going close to the same up front would work.
Luckily coil springs are fairly inexpensive and can be easily found on the used market if you want to experiment with different rates. Just remember after a certain point your shocks will not be adequate to deal with the heavier rate springs so you will need to revalve yours or step up to more pricey inserts/shocks.
