QUOTE(Mueller @ Nov 1 2020, 11:19 AM)
Looks like a Pro job to me, you might offer a hood hole cutting service now.
I’d go broke doing that for $$ and likely end up with a mental problem. After putting this project off over and over measuring and double measuring, also making a mark with chalk from the gas cap carefully lowering the hood making sure it was going to be in the right spot. Next drilling the hole (as I prayed) with a small drill bit and then larger drill. The actual hole was cut forever slowly by hand with the hole cuter to be sure of not f-king up. The high point was after drilling and seeing it was spot on!
