QUOTE(Mark Henry @ Nov 4 2020, 06:04 PM)
Thanks Mark
I made one complete set I hope, I know for sure one is a 911 part number and the dimensions match, but they had odd spacers on the spindles, are they a spacer or part of the old bearing? They knocked off like a bearing inner race but they're not conical.
These are Boge struts and the thicker hubs, I'm missing one of the spindle nuts, hopefully I can find one.
The other set I think one is a /4 strut, as it has a smaller lock nut thread. The other one the hub is 911 but it has a different inside fitting grease cap.
4 struts have a straight arm to to the tie rod, 911 is curved.
Later hubs have a small cap for the hub centric flange.
The odd spacer is needed on the strut to seal the hub with the rubber/metal seal on the back of the hub.
I did put a solid rotor on the front of my conversion car with a 912 M caliper and everything lined up fine. The struts had come off a 911T with vented rotors so I'm 99% on the struts being the same.
