YOU MAY DISREGARD THE BELOW
FOUND MY ANSWER IN IAN’S VIDEO
Hi guys,
I am about to install the tangerine ss fuel lines on my 2.0 74 (pump
is relocated to the front near the steering rack)
In the instructions I noticed that the longer line goes to the supply
and when I follow that line back to the front firewall under the
gastank I see a 9,5 mm on the passenger side and a 8 mm on the
driverside. Am I correct to say that 9,5 mm is supply and 8 mm is return ?
On fb somebody said that the 8 mm is supply and 9,5 mm is return (for his 1,8 liter).
Fyi both new lines are 8 mm so just need to know which side is
supply and which one is return....
Don’t want to screw it up
Thks
Dax
