wiring up a 1970 restoration project that I inherited totally apart. Making progress on the wiring. but the hazard lights work when the switch is pushed in (off), and they go off when pulled out (on). turn signals work, headlights work, high/low beams work, fogs work when lights in low beam mode.
any suggestions?
I switched out the switch with another one Ihad in a box. same issue.
first impulse is the power and ground wires are wired up in reverse?
