zprovo
Nov 16 2020, 04:55 PM
Click to view attachment Click to view attachmentIt looks like something is not connected at the very back of my transmission...
That hoizontal piece terminates in a coupling that is empty (except for gumpta)
hcdmueller
Nov 16 2020, 04:58 PM
Your transmission was either converted to a side shift and they didn't replace the tail shift nose cone, or the side shift cone was replaced with a tail shift version due to some sort of damage.
brant
Nov 16 2020, 04:59 PM
It looks like a tail shift transmission that was converted to Side shift
however they did not change out the rear tail cover when they did this
so the disconnected linkage is the old linkage that is likely not connected internally in any way
does it wiggle loose... when you turn the tail input shaft by hand?
zprovo
Nov 16 2020, 05:10 PM
QUOTE(brant @ Nov 16 2020, 04:59 PM)
Interesting. It doesn't budge by hand (I didn't put a tool on it).
Thanks for the info!
brant
Nov 16 2020, 05:11 PM
It could of been a damaged rear tail cone.
but if your car is a 1971
then someone updated it to side shifter
and didn't bother to change out the tail
you can buy a SS tail for it and easily change it in the car
or not....
zprovo
Nov 16 2020, 05:24 PM
QUOTE(brant @ Nov 16 2020, 05:11 PM)
or not....
Thank you sir!
rhodyguy
Nov 17 2020, 02:21 PM
That area above the plate on the bottom of the cover is loaded with gear lube. Looks like an attempt to stop a leak was done with RTV. There is a correct gasket for that task. The cover may be distorted too.
Al Meredith
Nov 17 2020, 02:48 PM
What I have done when I convert a Tail shifter to a side shifter and don't have a rear side shifter case I don't install the tail internal linkage and seal the long tail linkage holder with some JB weld and a freeze plug.
