dflesburg
Nov 17 2020, 08:19 AM
1970 car w/ new harness from Jeff for a 2.0
the wire for the heater fan is in the main harness to the relay board but there is no wire in the engine compartment for the heater fan in the engine comp.
Anyone know where to run one? Where should it be? Green and brown I believe.
JeffBowlsby
Nov 17 2020, 12:19 PM
Your 70 does not have the heater fan circuits in the main chassis harness. You need the 1970-71 ignition harness, even on a 2.0L, because that is what is compatible with your car re: the heater fan.
You could study the 70-71 ignition harness circuitry diagram and pick those circuits off the 12 pin connector. Just run them separately to the fan
pt_700
Nov 17 2020, 12:24 PM
came across a simliar issue putting a later 1.7 into my early chassis;
http://www.914world.com/bbs2/index.php?sho...p;#entry2850893have yet to figure out exactly where on the relay board to get power but, you might be better at figuring this out than i...
