QUOTE(fixer34 @ Nov 18 2020, 06:30 AM)
I don't disagree there are differences in bearing manufacturers. But there's something fishy here. There is no way a caged ball bearing will spin freely for that long no matter what the quality. The only time I have seen bearings spin like that is when they are worn, perfectly clean, and had compressed air on them.
Think about it; did you try this on your new front or rear wheel bearings? Did they spin at all?
Wheel bearing aren't high precession bearings. They are greased and have sealing rings in place. High precession bearings are for very high speed industrial machines built to high tolerances. They aren't prone to shock or exposed to the elements. Here are some of ABEC allowed tolerances of bearing ratings.
ABEC 5: 0.0035 mm (0.000138")
ABEC 7: 0.0025 mm (0.000098")
ABEC 9: 0.0012 mm (0.000047")
