QUOTE(Highland @ Nov 23 2020, 09:16 PM)
So here are the stats:
Battery Only - 12.8V
Assuming with engine off? Resting voltage should be 12.6V.
Engine Running 1000 rpm 13.3V
If you just started it, then 13.3V isn't bad as the alternator is working hard to recharge the battery after starting. If running for a while, it seems a bit low. What is the voltage at 2k RPM?
Engine Running 1000rpm Headlight switch on 12.5V
Need to know what the voltage is at 2k RPM. 1K RPM is marginal for the alternator to keep up.
High Beam on the rpm's drop and hunts - forgot to measure voltage
The voltage must be lower than 12.5V if it affects the FI.
So here are my questions:
1) I have a hard time believing the extra load from the high beam is bogging down the motor. Is the extra alternator mechanical load really that much or is the high beam draining from the ignition system causing erratic idle?
The electrical load shouldn't bog the motor down that much. It will slow a bit but shouldn't be much. What size engine?
2) Is 13.3V (no lights on) low? Should I be closer to 14V? Is this possibly more a alternator or voltage regulator issue?
I've read some of the threads and I think my grounds are good. The VR case to ground bolt reads 0.4 ohms. This is a new assembly car so I wire brushed all the ground stud landings (of course they can still be an issue). The transmission to chassis strap is in place.
Measuring resistance under 1 ohm is very difficult. Sometimes you can have 0.4 ohm just touching the probes together. It's best to measure voltages when running to get an idea of the health of the wiring and connections.
This is a D-jet car if it makes a difference.
Several things can be at fault including the VR, engine grounding, contact resistance of the battery terminals.
With engine running, lights on, measure:
1) Battery POS stud to its connector. You should measure zero volts.
2) Battery NEG stud (not its connector) to chassis ground. You should measure zero volts.
1) and 2) will test the battery connection to the electrical system.
On the VR connector on the relay board, measure:
3) D+ to chassis ground (not the engine). You should measure 14V.
4) D- to chassis ground (not the engine). You should measure zero volts.
5) DF to chassis ground (not the engine). You should measure 5-9V.
3-5 will test the VR and the grounding of the engine to the chassis. Let us know what you find.
