Hi everyone
Been unsuccessful with addressing the window gaps on my 74. Just resprayed and seals replaced from 914 rubber.
Difficult time closing doors with windows all the way up because the rear window needs to be jammed into vertical targa seal.
Have tried adjusting tilt and pillar nuts without success. Only bolt I haven't tried is the large one holding window to the regulator.
The rear portion of the targa top now also has gapping although latched in.
Front triangle window seal also seems to pinch with door closure. To shut door requires significant force with window up because it wont clear in the rear.
Is it the vertical targa seals? Do they usually need to be trimmed or other seals? Or just not able to make window adjustments.
Thank you for your suggestions and advice.
Click to view attachmentClick to view attachmentClick to view attachment[attachmentid=770
695] Click to view attachment
