Long story short. Changing out the 5 speed Boxster, for the 6 speed Boxster S.
I got the adapter plate from Kitcarchassis.com.
He recommended the Spec Clutch. SP902S.
Anyway, now that my new mechanic is starting in, there is some question as to the clutch being borderline heavy enough, or should be bumped up a bit.
The person I got if from says they are usually run a bit more than what they are rated for, and is a light car, and not using it for racing.
The clutch I have is rated for 485 ft/lbs of torque, and engine 473 ft/lbs of torque.
https://www.lmperformance.com/691949/sp902-...ster-s-32l.html
https://www.lmperformance.com/694385/sp903h...ster-s-32l.html
Not sure if I should keep the stage 2 or go with the stage 2+
