Flyinlow
Dec 11 2020, 06:39 PM
where do we suggest I purchase a quality wiring harness for my 74 914?
914Sixer
Dec 11 2020, 06:42 PM
New ones do not exist. Put a want to buy in classified (WTB). Jeff Bowlsby may be able to help you, he was repairing them.
Dec 11 2020, 06:48 PM
From someone on 914world.
Nobody is currently making new ones.
I have a spare chassis harness that I think is 73 or 74.
PM me if you are interested in purchasing.
Mark
Flyinlow
Dec 11 2020, 07:05 PM
Thank you i will do that.
porschetub
Dec 11 2020, 08:08 PM
If you have the main loom out (god forgive) and its not worth fixing ….many aren't anyway !! buy a used one and repair it properly with correct wire colours from your old loom using soldered joints and heatshrink or even better Duraseals which are very good, there are presoldered connectors but I have never used them.
Good luck.
JeffBowlsby
Dec 11 2020, 10:41 PM
QUOTE(Flyinlow @ Dec 11 2020, 04:39 PM)
You will need to clarify which harness you need. This thread presumes you need the chassis harness...not available...but do you need one or more of others?
Frank S
Dec 12 2020, 01:28 AM
Here you can get new harnesses, but unfortunately the Webshop is in German language only.
https://www.msbordnetze.de/porsche-914.html
JeffBowlsby
Dec 12 2020, 03:26 AM
QUOTE(Frank S @ Dec 11 2020, 11:28 PM)
In case there is a misunderstanding - I have been building 914 wiring harnesses for 20 years:
https://bowlsby.net/914/WiringHarnesses/
Frank S
Dec 12 2020, 07:09 AM
QUOTE(JeffBowlsby @ Dec 12 2020, 10:26 AM)
https://bowlsby.net/914/WiringHarnesses/Hi Jeff,
I know but I thought you don't make the chasis harness and they are making it.
No offence,
Frank
Bleyseng
Dec 12 2020, 09:52 AM
https://www.msbordnetze.de/porsche-914.htmlI used Google translate to convert the site to English. 2615 Euros incl tax for all the wiring harnesses (7) for a 2.0L 914.
Dec 12 2020, 10:16 AM
I'll take pics of mine today and post
TMM914
Dec 12 2020, 10:19 AM
You could check out Restoration Design.They have started manufacturing 914 911 and 356 harnesses.
BeemerSteve
Dec 12 2020, 11:05 AM
Kroon Wiring Harnesses are now in the process of building 914 chassis harnesses and the extra ancillary harnesses.
Dec 12 2020, 11:35 AM
All the new harnesses will be $2500 +
It just depends what you are looking for.
roundtwo
Dec 12 2020, 12:08 PM
I purchased a roller with no main harness. Jeff kindly referred me to these
https://www.aasesales.comWas able to buy a NOS 914 harness for $1500. Some of the rubber a little tired but the wiring still looking pliable, soft, sound. I ended up buying a new boot that’s located at the rear firewall from 914 Rubber.
As Jeff pointed out, be sure you buy the right harness for your year.
For any sub harnesses I’d go straight to Jeff.
Dec 12 2020, 01:29 PM
I’m pretty sure Aase only has ‘71 main harness.
It’s quite different from a mid year harness.
raynekat
Dec 12 2020, 04:22 PM
I used the Aase wiring harness on my build as my car was a 71 so a perfect fit. Most of this NOS harness was in great shape. A couple of the connectors had some wiring going to the wrong terminals that had to be corrected, buy other than that, mine was in excellent condition considering it had been sitting on a shelf for nearly 50 years.
