QUOTE(mepstein @ Dec 15 2020, 11:50 AM)
Always use the bracket to check. If they over expand, they can crack and then they are trash. Awesomepowdercoat sells new ones.
no need to head them much above the rated temp,if they only expand with higher temp the bellows is most like faulty.
I test with a head gun it takes little to get them expanded.
Only expand them in the bracket as mentioned,also never set the cable too tight when cold this will cause them to fail.
I also have tested with the stock cable and a shimano bike brake cable,the bike cable is a larger diameter and runs better on the roller...real cheap to buy around $6 for the one I used.
