QUOTE(VaccaRabite @ Dec 15 2020, 11:57 AM)
Very easy to make using the 700lb HF engine stands. Orange is the stand, grey is the metal I added. Car was on them for about a year, and then I sold them for a profit. It made work so much easier.
Zach
My plan exactly, I am working through the structural stuff now. RD has some nice parts and pieces but not everything. This work is similar to what I have been doing for many many years, historic restoration of our local historic buildings here in Buffalo. Save the good original material, remove the crap (selectively) and fabricate new materials matching original. Each splice is different and must be treated as such. This 914 will never see the track, but my intent is to recreate as close to original as possible.
Back in the '80's I glued together a Ghia convert shooting from the hip big time. Drove it for at least a few years after and was always reminded with the bad door gaps. They closed and locked, but could never get them right. My plan with this project is much more driven with layout. The "holding fixture" I am using allows for door installation but I will also be checking diagonals and level as we go
I was thinking the RD rotisserie, but now looking at the "modified engine stand" route.
Quick, simple, easy
Note that in those pictures I was not braced across the doors. I had VERY minimal welding to do on my chassis, and I did any hell hole work prior to mounting the car. But even with minimal hell hole welding I still put a 1/8th twist into the car and my pass side door gap has never been quite right. I didn't know any better at the time, and it was a hard lesson I had to learn. Which is why I was harping on it in your other thread.
I was able to shim the door to fit somewhat acceptably, though my gaps are not perfect. Putting your car on a bench will keep that from happening to your car. Its a very solid plan. The more places you can bolt it down the better.
