BPatenious
Dec 15 2020, 04:56 PM
Hi, this is my first post/question. I've been getting great advice reading some of the other posts, Thanks. I recently aquired a 1976 914 2.0 in great condition and I'm finding out how fun it is to drive. I'm sure this will sound funny but being 5'5" I have to move the seat so far forward to reach the pedals that the steering wheel is in my chest. Is there any good pedal extensions out there? I find alot to dress them up but none that would extend about an inch. Thanks
ValcoOscar
Dec 15 2020, 05:09 PM
Same here, I'm 5'8",
and years ago I lengthened my clutch pedal 1.00 by spicing it with an old pedal lever. Worked great!!!! I swear I was 5'-10" in high school
Easy fix
Oscar
Cairo94507
Dec 15 2020, 05:19 PM
Hi- Is your steering wheel stock? I am 5'5" and have a stock wheel and I do not have issues with the steering wheel hitting me in the chest. I ask because aftermarket wheels require an adapter that generally moves the steering wheel 2-3" closer to the driver- that is a lot.
930cabman
Dec 15 2020, 05:45 PM
Italian cars are built for guys/gals with short legs, German cars are not. I have used wood blocks screwed into the steel pedals on my 930. Only about 1" thick if I recall, but makes a big difference
rgalla9146
Dec 15 2020, 05:58 PM
Buy a loose brake pedal here from one of the regular
suspects.
Amputate the lever and reattach to your existing lever at your desired height.
A brake pedal has a flat lever that can be welded to the shaft of the clutch pedal
Coondog
Dec 15 2020, 07:41 PM
Who put the Pedal extension on my 914
bdstone914
Dec 15 2020, 08:02 PM
@BPatenious I have extra brake pedals if you want to weld a section into your existing pedals. I hear more complaints about the clutch pedal lenght from verticlly challenged drivers.
ClayPerrine
Dec 16 2020, 11:03 AM
I am 5'5" tall, and I just put the seat all the way forward.
I am not jammed up against the steering wheel. But all of our 914s have stock steering wheels.
Clay
Chris914n6
Dec 17 2020, 01:27 AM
Tilt the seat back?
There are plenty of pedal covers that bolt on, with longer screws and a spacer should get you an inch. 914 pedals are the same as 911 of the decade.
sb914
Dec 17 2020, 09:13 AM
abes914
Dec 17 2020, 12:32 PM
i am 5'6 and don't have the issue that you are having. i have the seats moved forward and tilted backwards i think. i drove a few years with stock steering wheels and now with momo prototipo.
I was once in a car show and saw this 356 with taped wooden blocks on the pedals.
I also remember some aftermarket pedals that clipped on the pedals. example like below...
90quattrocoupe
Dec 17 2020, 08:02 PM
My wife at the time I bought my 914 was 4'11". Using small carriage bolts, I put 1in thick rubber pads on the pedals. It worked fine and did not bother me at 5'10"
Greg W.
bkrantz
Dec 17 2020, 08:06 PM
Could we transplant about 3 inches of leg room from your car to mine?
