Okay, I think I need some schooling here because I'm not understanding how manifold vacuum could be better for advance. Following is my understanding so please tell me where it is wrong.
1. Advance helps during acceleration so should come on during partial throttle.
2. At full throttle, centrifugal advance takes over so the vacuum signal (and advance it provides) is not important.
3. Vacuum retard smooths and reduces emissions during idle when the throttle is closed.
Now for behavior of the ports and when they will receive a vacuum signal.
1. manifold vacuum port anywhere below the throttle butterfly either in the carb body or manifold itself.
- Vacuum will increase when the throttle closes as the running engine tries to pull
air past a closed butterfly valve.
- Vacuum drops when the throttle opens and pressure equalizes as air rushes in.
2. port vacuum just ABOVE the throttle valve
- Vacuum is near zero when the throttle is closed and little air is moving through
the venturi.
- Vacuum increases as the throttle opens and air rushes past the port opening.
3. the vacuum signal should be strong enough to fully pull the diaphragm in the vacuum canister to completely pull or push the advance plate in the dizzy. More vacuum beyond that doesn't provide any advantage but a weak vacuum could reduce how much advance or retard occurs.
So... while I can easily see that a manifold port would provide the strongest vacuum signal, it seems like the timing of the signal would be wrong for advance. I don't have my D-Jet throttle body handy so don't know where the advance port is in relation to the butterfly, but I can say that the Italian Webers I bought new that are already ported and tubed for advance and drilled for retard but plugged have the advance tubes installed just barely ABOVE the butterfly valves and the retard ports are below.
What am I missing?
I'm planning to run both advance and retard lines so want to make sure I understand what is happening.
