QUOTE(Superhawk996 @ Dec 20 2020, 09:09 PM)
@oldie914 Thank you so much.
I'll be tearing down a 901 case over the holiday for another member to have the case. Will take a close look at all the other info out there (factory manual, pelican links, etc.) and look forward to modifiying another one for 914 trans work!
If I were making another one of these tools, I wouldn't modify the 289d setting block but would make or buy a 5mm plate used in the VW 385 tool set. It is held by magnets to the pinion face.
I happen to be working on a 901/13 now that has an R&P with R=63.36. Taking account the 5mm plate thickness, the setting distance is 58.36. If you have a modified 289d with known setting distance of 57.71, then 58.36-57.71=0.65.
Adjust the dial indicator in the mandrel with the setting block to read 1.65; then put the mandrel in the case and read the dial indicator against the pinion face (including 5mm plate) with the goal to have it read 1.00. If it is more than 1.00, that is the gasket thickness needed to move the pinion away from the differential. If it is less than 1.00, bad luck because you have to disassemble things to put more shims by the pinion roller bearing.
