QUOTE(mepstein @ Dec 27 2020, 07:59 AM)
You need to use the 3.2 pump. It was a while ago but I remember Summit had the correct pump for a lot less than the usual suspects. Then go to a speed shop and get fittings to fit.
I’m using the GT3 pump with my DME. It doesn’t have the goofy size hose barb. The GT3 has a threaded hole instead so you can use AN fittings. Claudes buggies also sells AN fittings for the stock 914 tank. Makes connections much easier.
https://www.pegasusautoracing.com/productde....asp?RecID=6119https://www.cbperformance.com/product-p/3288.htmI used AN barb fittings with standard fuel injection rubber hose. For the track you would use steel braided lines.
