QUOTE(mepstein @ Dec 30 2020, 02:19 PM)
QUOTE(DRPHIL914 @ Dec 30 2020, 01:56 PM)
QUOTE(Lanner @ Dec 30 2020, 01:18 PM)
Hi guys,
My name is Lanner. I built this setup. It uses new iron hubs with radial brackets for use with stock 914 spindles. Bearings and wheel seals are stock 914 and it's bolt on. It's a good option that doesn't require swapping out to 911 suspension. Please let me know if you have any questions about the setup.
Thanks
Lanner
Click to view attachmenti do have a couple questions, since i have 5-lug fuchs(16") , but used the stock rotor and brakes in front with the rotor redrilled and new lugs pressed into the rotor, so currently i have all stock set up, but i do have 19mm 911 master cylinder, so my question is this: for my front if i converted over to this set up , what would i require? The boxster caliper and rotor, and the hub and spacer mounting blocks, is that it? and then source the new studs?(i want to use nuts not lug bolts)
@Lanner @djwayalso fyi i have 914/6 5 lug hubs on rear so just using the stock caliper with stock 4 lug solid rotor drilled for 5 lug(PMB), so for rear i would just maintain my current set up , or, if i wanted the rear boxster caliper would i just get the new rotor and caliper and mount with adaptor block? seems the new rotor would just slide right on my current rear hub but new caliper with spacer would be required, OR a 914-6 or M caliper could be used too?
Phillip - this looks like a great solution for putting big brakes on a car but I would hesitate to say it’s the solution for every car. I would put a Carrera rotor next to your stock rotor and check the weight difference then X 4 for the car. Adding pounds of unsprung weight to a narrow body four will affect acceleration and handling. Everything is a trade off and it really depends what you are trying to achieve.
We did the Boxster caliper, Carrera rotor upgrade on a lot of 911’s that got 3.2 or 3.6 engines. It’s a nice upgrade from M calipers.
S calipers have 3.5” spacing and are different from Boxster caliper spacing.
QUOTE(Lanner @ Dec 30 2020, 02:23 PM)
Dr Phil,
Correct on front setup. You need the hubs and brackets. You can get some nice screw in studs from BMW shops or 034 motorsports.
Correct on rear setup, you'd just need the radial adapters. The 914 hub will accommodate the Cayman caliper without any work. Note you lose the parking brake.
I have this setup on my car (vw) with 19mm master and works well. It's been on there for over a decade. I'd suggest maybe a slightly bigger master (20.6) if you want a really tall pedal , but I've left good enough alone.
On 16 fuchs the calipers need a little massaging, and maybe a slight spacer 5mm unless you have the 951 Fuchs. Pic of massaging here:
Click to view attachmentIn general you need 16" wheels. Some 15s fit (mainly the spare tire alloys such as 928/993 15" spare or 951 spare
Thanks
Lanner
Mark,
@mepstein , good point, there is a lot to consider before just jumping into this but exciting to see this is an option. maybe a better lower weight option is the alloy calipers that PMB has could work using this hub and adaptor, again, saving weight and not having to swap out the whole suspension for 911 when i already have good new other components.
Lanner, thanks for all the info and the pictures. i think you will get a lot of interest in this.
Phil
