QUOTE(Dave_Darling @ Dec 30 2020, 09:18 PM)
Did you set the timing at 3500 RPM? That figure is generally the "fully advanced" timing, not the spec at idle.
Usually the #1 plug tower on the cap is toward the left-front, not straight forward like yours has. But that is very dependent on the position of the distributor drive shaft, which can go in a number of different orientations. Haynes has a picture of how the slots in the top of the driveshaft should look when the motor is at TDC#1; I believe the slots are supposed to point about 12 degrees left (counter-clockwise) of straight fore-and-aft.
--DD
Thanks for the reply, I bought the Dansk distributor that Pelican offers for my car. I did set timing at 3200 but I rotated the distributor a little each direction and it only ran worse. All the plugs are black and look the same but I haven’t found any vacuum leaks and retightened carb intake. I checked valve adjustment and everything looks good. So I’m kinda at a loss now.
