QUOTE(Superhawk996 @ Jan 3 2021, 08:01 AM)
Without getting deep in the weeds. If it was running to your satisfaction before, don't go down the rabbit hole of changing emulsion tube sizing. I can't comment on the sizing - I've only run dual IDF's and DRLA's. You don't mention what your exact problem is so I'd only be guessing. However, emulsion tubes have nothing do do with idle jets. If you have an idle or transition issue, the emulsion tubes aren't even in play at that point. From the images I see online for Weber 36/32 carb, there should be an o-ring under the base of the jet holder (i.e. the brass screw head).
If you're missing those, I'd question who put the carbs together and whether you should just buy a complete rebuild kit and just go through the carbs completely. HOWEVER, if they weren't there in the 1st place, they won't account for whatever change that you're trying to troubleshoot.
When carbs go from running well one day (or one minute) and then start running terribly the next, it's usually debris that has been sucked into the one of the jets.
The other is be absolutely sure you aren't confusing a fuel issue for an ignition issue. Each presents symptoms in exactly the same way. Uneven idle, hesitation, poor transition to the mains or inability to achieve full power and/or full RPM's.
Also don't forget about all the other seals and gaskets associated with the runners, maifold plenum, and the runners to heads. Way to many failure points with that carb / runner setup in my opinion.
My recommendation would be to fully clean the carb 1st and use a rebuilt kit to refresh all gaskets, o-rings, etc., since that is where you currently are focused and working at. If that doesn't return to the same condition your previously had, then refocus your efforts on the ignition.
I really do appreciate the time and effort you spent misunderstanding and then replying to my post. Will try next time to ask less confusing questions, and I’ll look elsewhere for the emulsion tube sizes. Thanks
