QUOTE(Superhawk996 @ Jan 4 2021, 04:43 PM)
Sheesh . . . a doubting Thomas.
Not sure what experimentation you have in mind, but, know that measuring at quasi-static conditions will have no representation on valve rotation. You would be failing to capture the high acceleration loads imposed upon the valve train when operating at speed.
Unless you have a test rig that has Laser Doppler Vibrometry I'll wish you even more luck in observing and/or measuring the valve rotation.
I'm looking at a graph in a SAE paper 2012-01-0159 written by some gents from a company called Porsche and the rotational speed of the tested exhaust valve is nearly static until cam speed reaches 2000 rev/min. At a cam speed of 4000 rpm the valve rotation peaks at about 4 degrees per camshaft rotation.
Unfortunately I'm not finding the paper that outlines the effect of 911 elephant foot valve adjusters upon valve rotation as modified for application on a VW Type 4 engine.
If you're seriously interested in the paper text me.
Not just a doubting Thomas, but a professional doubting Thomas
. You confirmed my suspicion. The experiment I was thinking was just to set up a pair of valves dead center and another pair offset. Mark the valve stems and spin the engine by hand a bunch of cycles and see if there is a difference in rotation. I already suspected engine speed to be a factor so expected it to fail but hey, it's about the journey.
I am interested in that paper and will text. I'd also settle for a paper on the effect of 911 elephant foot adjusters on valve rotation on a 911 engine.
