QUOTE(ClayPerrine @ Jan 5 2021, 11:06 AM)
That is a great diagram. But my experience with DME relay failures made me go with two Bosch solid state relays instead. You can use this diagram, and replace the DME relay with the two in my diagram. Plus, square Bosch relays are available in your FLAPS, DME relays are way more expensive and only available from a specialty Porsche shop or the dealer. You can walk into a local auto parts store and pick up a generic horn relay for under 5 bucks that will work to get you home without a flatbed.
I understand that, and it makes sense. Currently, my difficulty is not knowing what is/was done to the engine ECU previously, save for the elimination of the 914-4 relay board, so I'm trying my best to combine all info and find a work through, as the car did work previously.
I figure my best hope right now is to get everything working as it was and proceed from there. Based on the diagram you drew , Clay, I've come up with this and added info from the other diagram as well, please let me know what you think, and again thanks for the help!
