I want to modify the engine with a new Piston and Cylinder Set with flat pistons.
Anyone do the modification ?
Do you modify the fuel injection and the ECU ?
Is it possible with no issues ?
914Sixer
Jan 5 2021, 06:50 AM
Straight up conversion. Euro Flat top pistons are 8 to 1 and USA dished are 7:6 to 1 . No fuel or ECU change. 5 hp gain.
Villemi
Jan 5 2021, 10:09 AM
QUOTE(914Sixer @ Jan 5 2021, 06:50 AM)
Thank you.
I think if I use an Euro exhaust line i will have more Hp.
If i use a big bore european kit (96x71) for 2056cm3 no more change for fuel and ECU too ?
Bleyseng
Jan 5 2021, 10:18 AM
Using the early style heat exchangers will increase the HP too along with the flat top pistons. You should always check your Air Flow Ratio with a wide band O2 setup as changing anything in the engine can change it.
Villemi
Jan 5 2021, 10:29 AM
QUOTE(Bleyseng @ Jan 5 2021, 10:18 AM)
Thank you Excuse me 914 worl is new for me.
How do You check the Air Flow Ratio with a wide band O2 ?
Jan 5 2021, 11:39 AM
I’m not trying to be a smart ass but it’s probably better to check google and YouTube to get the explanation. It’s not 914 specific.
914Sixer
Jan 6 2021, 06:53 AM
IF you go 2056 your MPS will need retuned.
