QUOTE(FL 000 @ Jan 7 2021, 11:27 AM)
I just had my new Dansk show up 2 days ago. Not sure if it is the one you are after but is part # 914-201-010-12. I can take some pics also if interested.
I installed one in my 75 over the summer. All worked fine right out of the box.
Idiot alert: After installing the tank I found, buried at the bottom of the box, a note from Manufacturer explaining the new tank “cleaning procedure”. They want you to spray it out with carb cleaner and gasoline before installing. Needless to say it’s better to do this before the tank is installed in the car!
Good luck!
