QUOTE(bkrantz @ Jan 8 2021, 08:59 PM)
Can somebody confirm the correct order of the wiper shaft bushings? This is what makes sense to me. The screw driver shows the position of the cowl sheet metal.
When I put my wiper assembly back in, this is the order in which I put the parts:
Going left to right:
- Wiper shaft
- flat washer
- cupped washer facing out (the one in the upper right corner of your pic)
- rubber grommet with raised lip facing out (the one to the right of your screwdriver)
- cowl sheet panel
- rubber grommet with recess (the one to the left of your screwdriver)
- cupped washer facing down
- nut
- plastic cover,
- wiper arm
- black acorn nut
Basically, the only differences between your pic and what I did was to add the "extra" cupped washer between the flat washer and the rubber grommet inside the cowl, and switched the rubber grommets (the one with the lip on the inside facing out). By putting the grommet with the lip on the inside, it makes it easier to center the wiper shafts in the holes in the cowl.
