I have a 75 1.8 with L-Jet. I have the motor out to replace some seals, and I'd really like to run it to check for leaks before I reinstall. What all do I need to have hooked up to get it to run out of the car?
I was planning to run a remote start switch, so just getting it to turn over shouldn't be a problem.
I plan to have:
1) The air intake and air flow meter connected
2) all the temp and pressure sensors, AAR, etc.
3) All the vacuum lines
4) fuel injector resistor pack
5) L-Jet brain box
Do I need the dual relay if I just hotwire the fuel pump?
Where/how does the L-jet brain get the signal from the ignition switch?
Do I need anything from the relay board?
