QUOTE(B2524 @ Jan 9 2021, 02:19 PM)
What new parts were used in the rebuild?
New mains and rods , new rings ,new oil seals and gaskets. The valves were lapped and the exhaust ports were opened up , I do this to 1.7 heads because the exhaust ports don't open up to the gaskets. I do balance the pistons and the rods and on this engine I did not install the "head caskets" . If you are interested I have a direct reading oil pressure gauge installed so I can tell you the pressures and I can do a pressure test on the cylinders as well. As I remember the oil pressure was 40 PSI while cranking without plugs . AL
