I'm removing the A/C evaporator inside the cabin and wondering if I should take the quick and easy way, and just cut the rubber hoses? Or, do I need to remove them carefully?
I don't know if those are easy to buy new, or could someone make them if they were to try and install the A/C again?
The compressor is already removed, so I'm removing the evaporator now. I plan to remove the condensor and plug up the holes, etc, but it may be a while before I can do the rest of that. So, my first thought was just to cut the hoses up short under the dash and leave them to fill the holes until I can get the other work done.
Any thoughts are appreciated!
