Hi guys,
Last week I managed to install new oil cooler seals and the oilpressure switch which made an end to an oil leak coming from above my oil filter. Don't have to tell you that the job was a PITA
Now I notice that I have another drip coming out of the inspection hole between the engine and the transmission. Read everything (I think) I could find and I think that the crankshaft seal/rear main seal is leaking.
I have no idea what the condition of my clutch is but I've read that if I take off the flywheel that I should need to replace a few things. Is it correct that I can't re-use the pressureplate, flywheel bolts etc ? What parts can I re-use and what parts do I need to replace ?
- flywheel bolts ?
- feltwasher
- pilot bearing ?
- lockplate ?
- o-ring crankshaft to flywheel
- clutch release bearing ?
Is it perhaps better to replace the entire clutch while I am in there or can I just replace the rear main seal ?
thks yr advise
Dax
