mb911
Jan 21 2021, 07:29 AM
I thought this is a needed information for the group. I have been sending brackets and straps with the mufflers for a while but recently switched to a better strap that I have laser cut but isn't as bulky as the old ones but does require you to bend them around the muffler to form them. It takes 10 seconds per strap to do. Below you will see the straps as they come, then after you bend them around the muffler and then of the bracket for reference. Let me know if you have any questions. Also note these are designed to protect your investment from failing prematurely. The factory design is pretty silly and cantilever the muffler. Ugh
Click to view attachment Click to view attachment
campbellcj
Jan 21 2021, 08:14 AM
I've been super happy with your bracket - got the right sizes of straps like those at McMaster Carr that fit the couple different mufflers I have.
VaccaRabite
Jan 21 2021, 08:37 AM
Is there an advantage to these straps over the T-bolt clamps you had been using? Cheaper? Stronger?
Also, in the first picture is the nut welded to the strap and captive? Trying to figure out the lack of a washer on it.
Having used Ben's muffler hanger - its much better then the stock hanger.
Thanks!
Zach
mb911
Jan 21 2021, 08:46 AM
Sorry the washers are not oriented correctly they should be on each side. The nut is not captive. The reason for the switch is these are stronger then the ones I was using and a bit more hidden. I felt they were just a better way to finish out the install.
