Too many factors for a standard measurement; manifolds, gaskets, spacers, etc. I recently worked on a kind of a Frankenmotor that wasn’t symmetrical
Mark Henry
Jan 22 2021, 09:07 AM
My stroker engine is around 3/4" wider than a stock engine.
Ballpark stock engine outer intake manifold stud is a bit over 24" If you're measuring for something say linkage don't do this until you have a completed long block.
Jan 22 2021, 03:49 PM
QUOTE(IronHillRestorations @ Jan 22 2021, 06:13 AM)
Jan 23 2021, 02:30 PM
I was installing a CSP bellcrank linkage on the engine I mentioned and I had to space the center bellcrank to one side so it was perfectly centered between the two carbs. This was the 3rd CSP I’ve installed and the only that needed that
