draganc
Jan 25 2021, 12:42 AM
Hello folks!
I'm looking for advice and recommendations on a 2 post car lift with
top only connection.
Lift capacity 9-10,000 lbs for “medium” commercial usage, such
as 2-3 car/week.
I have seen a lot of them between $1750 to $2200, incl free shipping,
mainly from Atlas , Triumph and Stratus.
Used “name” brand vs new budget brand as above mentioned?
Need one within the next week or so and are located in NJ.
Open to opinions and recommendations.
Thanks,
dc
mate914
Jan 25 2021, 07:01 AM
Find a dealer going out of business or up grading the lifts.
Name brand from before China made it, is your best choice.
Jan 25 2021, 07:24 AM
If you decide on the Atlas lift, greg smith equipment is 5 minutes off 95, exit 1 in Delaware. Save the sales tax and prices are better if you pick up.
VaccaRabite
Jan 25 2021, 07:33 AM
Is this for a shop or a garage?
Many of the 2 post lifts you are talking about need 11-12 feet of clearance to fit in your shop. That's a hell of a tall order for your usual garage. Also, some of the commercial lifts are going to require more then single phase wiring. Just remember to be sure the motor on the lift you are looking at is single phase. Most (all?) light duty lifts will be fine.
There is a 2 post 9 foot lift that is specifically made to fit in the usual garage, but it has the joiner on the floor, and can't lift quite as tall (6.6ft). (edit - now there are two.
The NW brand and Tuxedo.)
https://www.bestbuyautoequipment.com/nation...HBoC9WcQAvD_BwEhttps://www.bestbuyautoequipment.com/tuxedo...p/tp9kf-tux.htmAnd there is the MaxJax that has no joiner and runs on 120v but only lifts your car about 4 feet off the ground (this is what I have).
I linked to Best Buy Automotive as that is who I went through and they were good people when the equipment I ordered ended up getting backordered. They never got frustrated with my status calls and we always trying to assure me that things would arrive when the lifts cleared customs. They have an office in NJ, but I do not know where. Mark mentioned Greg Smith - they are also a very solid company to deal with.
Also, nearly everything new is going to come from China, or be an order of magnitude more expensive.
Zach
dhuckabay
Jan 25 2021, 07:36 AM
Have a China one, off eBay. Gets used every day. Well built.
draganc
Jan 25 2021, 07:47 AM
QUOTE(dhuckabay @ Jan 25 2021, 05:36 AM)
Could you post some pictures please or provide at least the name/type? Thanks!
draganc
Jan 25 2021, 07:51 AM
Thanks for all the feedback. Additional clarification, height and 2 phase power is not a issue.
Also, thanks
@mepstein GSE pick up tip in Delaware!
Jan 25 2021, 08:35 AM
QUOTE(VaccaRabite @ Jan 25 2021, 08:33 AM)
Zach
I just purchased a Maxjax from Bendpak. I'm pretty sure Danmar sold the product to Bendpak and they are the only distributor for them. I no longer see them sold through places like Costco or Home depot. They shipped my direct and it worked out well. They made some upgrades to the unit but and it sells for more. My garage height is only 8.5' so I had fewer options than the OP.
SavingManuals
Jan 25 2021, 08:56 AM
[/quote]
[/quote]
@mepstein Any issues with the Maxjax so far? I was considering it
Jan 25 2021, 09:33 AM
[quote name='SavingManuals' date='Jan 25 2021, 09:56 AM' post='2885590']
[/quote]
[/quote]
[/quote]
I have not installed it yet. All the reviews of the new model are very positive. For my garage, with its limited height, it’s the only 2 post lift available. I could have used a mid rise lift but I’m pretty sure I can stack one 914 above and another below with the maxjax. That’s not my only reason for purchase but one possibility. All the lifts offer benefits and compromises. You just have to figure out which one is best for you.
GregAmy
Jan 25 2021, 09:53 AM
I installed a Bendpack, a commercial-grade used unit from a garage that was going out of business. Standard height, we modified the garage bartn to make it work. Love the thing.
Mark Henry
Jan 25 2021, 10:02 AM
My Ammco is 12'-3", it really 11'-11" tall but at full rise the freaking ram's stick 4" out the top. Without any pad risers a 914 bottom is 6'-2"-ish high down the middle, My 6'5" kid ducks or he hits his head.
I choose a well maintained used USA made lift, I removed and installed it by myself. The seller had a forklift and I have a 2 ton crane in my shop to stand it up.
With the overhead bar type of lift some trucks, vans, etc., you can't lift them as high as you might like. No problem with most cars and you can lift tall vans enough to do most jobs.
QUOTE(draganc @ Jan 25 2021, 08:51 AM)
Also, thanks
No such thing as 2 phase power, single and 3 phase only. 220-240v is still single phase. You want single phase, unless you're commercial.
VaccaRabite
Jan 25 2021, 01:26 PM
QUOTE(SavingManuals @ Jan 25 2021, 09:56 AM)
Buy one and don't look back. They are fantastic. But they are not commercial units, and only raise about 4 feet. For a hobbyist like myself, its very good.
Zach
Calwaterbear
Jan 25 2021, 02:10 PM
Just remember you need significant concrete footings to support your 2 posts. If i remember right my 10K lb western required 2foot X 3 foot X 1 foot deep at the mounting points. the rest of the pad was 3 inches, but I had to dig out and rebar the mounting locations before I poured the slab
jhynesrockmtn
Jan 25 2021, 02:38 PM
QUOTE(draganc @ Jan 24 2021, 10:42 PM)
Hello folks!
as 2-3 car/week.
Thanks,
dc
Mine was bought locally and installed by a dealer. It's a 10k "launch tech". I bought the 4 post from them at the same time and negotiated a bit of a discount. Maybe you have a similar type of dealer locally.
https://www.cemlifts.com/Click to view attachment
Jan 25 2021, 03:07 PM
QUOTE(Calwaterbear @ Jan 25 2021, 03:10 PM)
4” for a Maxjax.
Bucci
Jan 25 2021, 03:42 PM
Not sure if this will fit your application, but I’ve been reading about this lift on the other forms..! I think I’m going this direction as my garage ceiling is only 8 feet tall plus this one you do not have the bolt down you could fold it up and lean it against the wall. I’m only lifting a 2100 pound 914.!
https://www.ezcarlift.com/
Rrrockhound
Jan 25 2021, 04:34 PM
I've had a MaxJax for over 10 years now and have had it at 3 different properties. The 4' lift height is low but with a roller stool you can move around easily under the car. I had my latest garage custom built taller than standard so I have clearance for an SUV. I put a rolling door at the service bay so I don't have to worry about an open garage door interfering with the car while it's lifted. The MaxJax is rated at 6000 lbs but it does labor a little with my 4600 lb Mitsubishi Montero. For my current installation, I had a hydraulic shop fab up a pair of extension hoses so I could run the hoses up into the rafters and down the walls to the hydraulic pump rather than running them across the floor. Then I took the pump off the cart and mounted it directly to the wall.
930cabman
Jan 25 2021, 05:11 PM
I have been using a HF scissors lift for about a year now, works good. Some guys dig a pit and flush it out with the floor. Our Alfa spider can drive on, set the lifting pads and go. Our 911, 914 and 930 require a double layer of 2x10 lumber to get it up for clearance. I simply have it sitting on my floor slab but have it pinned to the floor and have leveled it. Currently rebuilding our 914 rustout.
Cornerlot
Jan 25 2021, 05:26 PM
About 7 years ago a local company went out of business and sold off about 40 Rotary lifts, U.S. made ones. I bought a 9000# asymmetric version, runs on single phase 220V. Easy to put in, I did it myself and consider it the best tool in my garage. Well worth the cost, about $2400 used.
ClayPerrine
Jan 26 2021, 08:48 AM
When we had our house built, we had 10' ceilings put in the garage. I found a local Fort Worth company, Gemini Lift, that was willing to build me a 2 post lift that would fit under a 10' ceiling. I love it. No more laying on my back in cat litter.
But it does have it's drawbacks. It is fine for a 914 or our BMW, but if I put my truck on there, I can't raise it high enough to stand up. So I just sit on an old office chair.
Disclaimer... y'all know I am "vertically challenged". So putting a lift in a 10' tall garage won't work for most people.
Clay
930cabman
Jan 26 2021, 05:44 PM
Life with a lift, add heat in the winter, some decent lighting, enough room to get around,.... makes this backyard wrenching much easier. Enjoy and be safe wile under the lift
draganc
Feb 8 2021, 11:09 PM
Thanks for everybody’s input!
I pulled the trigger on a used Atlas pro-v10,
two post asymmetrical 10 ton lift.
The lift is about 10 years old and fully operational
but it does sweat a bit of hydraulic fluid at one of
the cylinders.
Surprisingly Atlas doesn’t service the older model
anymore and google wasn’t really helpful finding
a online parts dealer/store.
Any good recommendations for hydraulic parts dealer?
Thanks again!
mate914
Feb 9 2021, 08:27 AM
QUOTE(draganc @ Feb 9 2021, 12:09 AM)
the cylinders.
Thanks again!
Its mostly o rings in the ram. open up and clean, shops put tranny fluid in(old or new).
The o rings are findable.
Matt
jd74914
Feb 9 2021, 09:47 AM
I've used Fremont Industrial Supply and been happy with their seal kits. That said, I've only ever bought them for my Deere backhoe, but they have lasted well and I probably abuse that thing more than any lift ever.
Just checked and they show Atlas on their list of cylinder kits. If they don't have your model you can always call them and they might be able to help as well. Most cylinder seals are pretty similar, big thing is knowing the shaft and bore size.
https://www.fremontindustrialsupply.com/hyd...nder-seal-kits/
Bullethead
Feb 9 2021, 11:02 AM
QUOTE(Cornerlot @ Jan 25 2021, 06:26 PM)
I have the same lift bought used (4 years old at time of purchase)... got a great deal, the best $2000 I've spent. Check your local marketplace FB, CL, etc. They're out there.
