DavidSweden
Jan 25 2021, 04:20 PM
2.0 motor
I have some 1.7 rockers with 911 swivels which I am thinking about installing.
Questions:
Will type 2 Vanagon spacers (part 021109433) fit the 2.0 rocker shafts?
Will I need new push rods?
Thanks in advance
914werke
Jan 25 2021, 06:25 PM
Yes, but to do it right you should install & measure your adjuster to tip alignment & shim (or machine) accordingly
Mark Henry
Jan 25 2021, 07:03 PM
Is this a stock or stock-ish 2.0?
There's little to be gained on a stock engine other than a lot of extra work.
I use 1.7 rockers and SF adjusters on performance engines where I use HD dual springs with pressures that will damage the stock adjusters and the valves.
