Im finishing up the wiring part of my 2002 H6 conversion with 2002 WRX manual transmission. Ive been trying to figure out the VSS and neutral switch wiring. I have seen some diagrams on the site, but not entirely clear and I want to be correct. My VSS sensor at the tranny has a Green, Brown and White wire (looking in the plug left to right). My understanding is Green= signal, Brown=ground, white= 12v switched. I also believe the green gets tied into a reduced 5v switched signal and then to the ECU (pin 134-1) is this correct?
Also, hoping for some clarification on the neutral switch wiring. Not overly concerned about running an alarm starter interrupt or clutch pedal switch unless necessary. Really appreciate any help. Thanks
