QUOTE(davep @ Jan 30 2021, 12:38 AM)
Normally the resistor is connected to the cylinder head temperature sensor. It acts as a fixed resistance to modify the variable resistance of the sensor. I am not sure what the wattage of the device is, but from the size it may be 10 to 20 watts. Also very rugged for use in a hostile environment. If I remember correctly, it is used for the 1973 2.0 only. It kind of converts the FI components of a 1.7 to work with the 2.0 engine IIRC.
I don't think it was your intention, but, beware of the temptation to imply the 1.7L FI components can work for the 1973 2.0L FI
ECU is unique to 73' - not shared with 1.7L
037 ECU is used on Both the 2.0 and 1.7 in '73MPS is unique to 73 and not shared with 1.7L
TPS is unique to 2.0L
Injectors are unique to 2.0L
CHT sensor is unique + resistor in series that adds 270 ohms to whatever the sensor outputs. These CHT resistors are unique to 73' 2.0L setup. There is another thread currently being developed to show difference between the 1973 017 CHT sensor and the 012 sensor. The difference is substantial at lower temperatures during warm up.
Note the resistor is no where near 10W-20W which would require a heavy ceramic housing to dissapate that kind of heat. That plastic cigar housing is just there to protect the resistor from weather, chemicials, etc. There is no significant current flow though the CHT resistor. Any current would be on the order of milli-amps.
Brad Anders site lists it as 1/4W - 1/2W, which seems resonable. Personally, I'd go 1/2 watt but I'm sure that is overkill by a large margin.
Here's picture of the resitor in my parts intended to build up a 73' FI system to match my vehicle's build year. Slightly different that the other two posted in color, size and connectors but same function. From picture from
@Morph914 it does appear there was significant variation in them.
