QUOTE(mepstein @ Feb 9 2021, 12:25 AM)
Horsepower means nothing when it comes to braking. Only mass and velocity.
but will add the other important factor is tire friction (mu). And a slight correction -- what matters is acceleration (deceleration). Acceleration is the change in velocity per unit of time.
You don't need big brakes if your going 60 mph but have miles and miles to stop. If you want to stop in 130 feet, that will take some bigger brakes.
To elaborate on Mark's math:
Force = mass x acceleration So where does the Force side of the equation come from? The tires!
Force = Tire mu x weight on the tire is the equation that defines tire force.
So the entire system is governed by:
Tire mu x weight on the tire = mass x acceleration.Mass is set by the vehicle itself and acceleration (deceleration) is determined by the driver.
Therefore,
Braking distances are determined by braking forces over a period of time, but, are ultimately dictated by what the tire can deliver. . We won't go down the path of the math to determine braking distance.
Giant brakes on hard rubber and/or skinny 4.5" tires of the 60's and 70's will still have terrible stopping distance.
Braking endurance is determined by the size of the components which provide thermal mass to keep fade at bay as previously pointed out.
Yeah, there is a lot more to brake sizing (balance, effectiveness, pedal feel, etc.) but I find most folks don't really appreciate that stopping distance is set by the rubber.
So when you say you need bigger brakes, the question is to really ask why?
If you can lock up the brakes, what you really need is better tires. When you have so much tire that you can no longer lock up the brakes, now it's time to mess with the brakes.
