They do not show a part that matches that part number. Your search looks for all grommets. The only one that looks close is this which is described as 24mm rubber sleeve. the CHT hole is 26mm.
MartyYeoman
Feb 9 2021, 04:01 PM
QUOTE(IronHillRestorations @ Feb 9 2021, 06:34 AM)
Pretty sure I have some factory grommets. I’m traveling today and I’ll get back to you
Thanks, Perry Don't need to be pretty, just functional.
adolimpio
Feb 9 2021, 08:16 PM
Amazon has an assortment of solid grommets that allow you to add whatever hole that you need. That's where I got my CHT grommet, and numerous others.
Go to Harbor Freight and buy the Grommet Kit. I took one that fit the main hole well, and then fit a second grommet in the hole of the first one. Seals tight and has a small hole for the wire to pass through. Bonus: You get lots of other grommets and its like 4 bucks. If you really want it to hold, you can do a little gluing / black RTV one grommet in another. It was an easy fix.
Feb 10 2021, 08:13 AM
Sorry it’ll be Friday. Changed plans due to weather
bdstone914
Feb 10 2021, 08:58 AM
QUOTE(bdstone914 @ Feb 9 2021, 09:34 AM)
QUOTE(Fosterjoejr @ Feb 8 2021, 07:53 PM)
QUOTE(MartyYeoman @ Feb 8 2021, 05:25 PM)
Kinda says it all. Any available somewhere? Item #30 in the attachment.
Edit. I had an OEM Porsche gromett that had the same referance number as the 914 Rubber part. It fits in the hole with some slop but looks like it is will work ok.
MartyYeoman
Feb 12 2021, 09:43 PM
QUOTE(adolimpio @ Feb 9 2021, 06:16 PM)
If you do order that gromett olease report back if it is actually available. It is said to be genuine and special order. Or call a VW dealer and ask them. I know that sometimes the same part that may be discontinued by Porsche is available from VW.
That Amazon assortment has a 25.4 mm gromett that should work in the 26mm hole.
MartyYeoman
Feb 15 2021, 12:38 PM
QUOTE(bdstone914 @ Feb 15 2021, 07:14 AM)
QUOTE(JamesM @ Feb 13 2021, 03:48 AM)
When looking for parts, always remember you are driving a Volkswagen
I went with the Amazon grommet set.
Arno914
Aug 12 2021, 09:37 AM
When looking for parts, always remember you are driving a Volkswagen smile.gif
VW Classic has them (at least in Germany). Got mine today (incl. one spare, you never know...25 years from now…)
